cheapish decoder
Discussion in 'AV Receivers & Amplifiers' started by apul, Jan 18, 2003.
  1. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    hi all, im in need of a DD and DTS decoder that wont break the bank. It only needs to decode DD and DTS, it doesnt need an in built amlifier as my brother is brewing his own home built one. just need the decoder bit. Needs to accept optical and coax and output 6 channels (5.1) or more.
    thanks
  2. EvilMudge
    EvilMudge
    Cheapest your going to find is probably the Yamaha DSP 800, though this has three channels of amplification for centre and rears.
    Even low end processors (totally without amplification) start at around £900. If that seems reasonable then Rotel or Cyrus are probably your best bet.
    TBH Your best bet is a cheap AV amp with pre-outs - forget the internal amplifcation and use it as a processor.
  3. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    yeah £900 is way too much
    was thinking that i would have to get an amped one, but just seems a waste if im not going to use it.
    will keep looking thanks.
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
  5. MikeC
    MikeC
    Mar 14, 2001
    224
    Northants,UK
    +10
    apul
    since you havn't mentioned a specific budget, one option could be a 2nd hand Sony TA-E9000ES.
    Originally they sold for about £1K but would probably go for under £500 .. maybe less used ..
    Mike
  6. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    thanks for the replies, that SH AC500D looks quite promising, some places have it for quite cheap saw a place with it for $75, but no stock left, all are in the US but cant find any in UK.
    and £500 is quite over budget im afraid.
    anything else?
    thanks
  7. clam
    clam
    Sep 1, 2002
    West Country ooo arr !
    If you are still looking I have a SH AC500D which may be available soon as I am planning an upgrade.
    If so what's your budget, I don't really want to "give" it away as it's such an excellent bit of kit.
  8. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    See if you can dig out the following:
    Denon AVD-1000 (DTS)
    Denon AVD-2000 (DD)
    Millenium 2.4.6 (DTS)
    Yamaha DDP-2 (DD)
    Not aware of any model which can do both.
    Otherwise considered an AV preamp/processor?
