Cheapest Wireless?
Discussion in 'Xbox Forums' started by Rick1486, Dec 26, 2006.
  1. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Hi all and Merry Crimbo!
    I love my new 360, but wish it came with wireless already a la the wii.
    Where is the cheapest place at the minute to get a wireless adapter from? 60 odd quid seems a lot and I'd like a better bargain if I can get one, so if anyone can point me in the right direction I'd be grateful.
    Rick
    edit: I also want to ask if they're all as noisy as mine is - admittedly I've got an intercooler on the back of it, but the thing sounds like a jet engine - is this the norm or is it to be expected with the intercooler (I asked for it as I was paranoid about the 360 overheating).
  2. shirehorse99
    shirehorse99
    Dec 11, 2002
    22
    3
    buy a zoom gamepoint from ebuyer for £35.
    Easy to setup and works a treat
    Shire
  3. DJC013
    DJC013
    Dec 2, 2006
    72
    11
    Horsham
    +3
    Cheapest i have found so far is PC World, at £49.99. Hope this helps, Damian. :thumbsup: PS Thats for a Microsoft Official one.
  4. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Thanks v.much, anywhere else with cheaper deals at all? :smashin:
  5. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Please also see my original post as I've edited it to ask about noise.
  6. BFassassin
    BFassassin
    Sep 27, 2006
    294
    +10
  7. Sword
    Sword
    Dec 7, 2004
    372
    +6
  8. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,958
    2
    Manchester
    +4,473
    No probably not, he's just probably offering information freely available on the internet though. If you want to connect to a wireless network you need the MS USB adapter or a wireless bridge that works without drivers. All cost around the £40-50 mark, no jiggery-pokery can get you round this.
  9. jasper1
    jasper1
    May 23, 2005
    75
    Nr Oswestry
    +12
    I wouldn't bother buying that info as it is freely available on the net.
    I managed to get my daughters xbox360 connected this way but it is a bit of a pain as basically you have to have the pc on and connected for the xbox to be able to connect through it as a network. Its ok until I can afford the wireless adapter though.
    There are two ways to do it:
    If your pc has a usb broadband modem and an ethernet card (most new ones do or you can buy them for a tenner) you can connect the xbox 360 with the included ethernet cable to your pc and then run the network wizard.
    Or as in my case, I have a wireless router and her pc connects to that using a usb dongle and then the xbox connects to her pc's ethernet connection. Again I just ran the network wizard.
  10. jc0v
    jc0v
    Dec 26, 2006
    44
    bridge your pc/laptops lan connection and wireless connection and connect the 360 to the network port of the pc/laptop(which is connected wirelessly to your router). In windows you do this by highlighting the two connections in "network connections" right click then "bridge connections".
  11. rickyjohn
    rickyjohn
    Feb 20, 2006
    441
    28
    +23
  12. rickyjohn
    rickyjohn
    Feb 20, 2006
    441
    28
    +23
    Bump - anyone answer my post above?
  13. Russellgti
    Russellgti
    Nov 4, 2005
    523
    28
    +29
  14. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Thanks gang, I've sorted it now by biting the bullet and buying the ms adapter. I have to say it's superb - a doddle to set up and just works (unlike the fannying around we have to do with pc stuff).
    Rick
  15. deakodude
    deakodude
    Oct 7, 2005
    317
    warrington,cheshire
    +17
    I purchased the ms wireless adapter and notice every couple of days the 360 does no know its connected when I attempt to sign in.I then have to do the tests again to set up? anybody had similar problem?
  16. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
    Sometimes for me I try to sign in and the right hand blade opens saying couldnt connect test connection? I say 'no' and the blade disappears and i'm signed in on live! Strange behaviour, can't figure out why that happens.
    I've only ever had the console not see the adaptor is plugged in, just unplugged and plugged it back in fixed that.
    Never had the adaptor discount from my wireless router making me have to connect it again though.
  17. davieg1
    davieg1
    Dec 5, 2005
    590
    2
    Aberdeen
    +45
    This happens to me on a regular basis and I am currently wired straight to pc with ethernet cable. I sometimes click yes and it finds everything and when i sign in again it connects immediately
  18. Sword
    Sword
    Dec 7, 2004
    372
    +6
    I got mine here - good price and next day delivery too. Worked out the same as PC world...
    http://cgi.ebay.co.uk/ws/eBayISAPI....MEWA:IT&viewitem=&item=190066392553&rd=1&rd=1
    Tell you what got me though - all my other wifi devices have had to have their mac addresses added to my wireless router to work, as well as the 26 key code - but this one only needed the code, no mac address addition! What's that all about?
    Sword
