Cheapest way to get freeview with no signal?
Discussion in 'Freeview & YouView' started by Jamo218, May 4, 2007.
  1. Jamo218
    Jamo218
    Apr 30, 2007
    97
    Manchester
    +9
    To my dismay, I bought a TV with an inbuilt digital tuner but am in an area with zero signal until 2009! It's looking like i'll have to pay for some kind of cable/satelite service, but which one? Is there anything good without ongoing cost?
    Anyone been in a similar predicament??
    BT Vision appears to be a possibility?
    Thanks in advance!!
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
  3. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Have you tried to get a digital signal with your existing aerial or just gone by one of the post code checkers. They can be inaccurate/ pessimistic.
  4. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    Have to agree with Richard, in a thread two weeks ago a person also stated the same issue, once he gave his post code out it became evident he was being supplied false info. Where do you live?
  5. Jamo218
    Jamo218
    Apr 30, 2007
    97
    Manchester
    +9
    Thanks for taking the time to reply!
    I have checked the Freeview site which states that Freeview is not available in my area. I also managed to look at one of those sites that shows you line of sight to nearby antennas and what I believe to be the closest one is blocked.
    I live in a block of apartments (recently purchased) and have just received a new Sony Bravia KDL-40w2000. I've literally just plugged it into the wall and have scanned for a signal, then checked the net which so far indicates no freeview.
    I live in Glossop SK13
  6. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    According to the DTG checker
    http://www.dtg.org.uk/consumer/coverage.html
    parts of Glossop at least should already receive all the Freeview channels. I used SK13 8LX as the checker needs full post code. Presume you are using a communal aerial perhaps it is still set up for analogue?
    As I said above these checkers are not all that accurate; they do not take very local factors into account and you may be in a different part of Glossop anyway. :). I do find that DTG one better than most however.
    One more idea; Dont know your TV but some dual standard TVs (analogue and digital) like yours automatically scan for both analogue and digital but some have separate scan programmes in the menu. Make sure you have scanned for digital as well as analogue.
  7. Jamo218
    Jamo218
    Apr 30, 2007
    97
    Manchester
    +9
    From the link posted above:
    Digital TV is likely to be available from 1 provider:
    Satellite television
    Through a satellite dish from Sky: www.sky.com and Freesat from Sky
    Freesat sounds like it could be the answer.
    Thanks.
  8. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Personally I would as a last throw ask a few neighbours in the block what TV reception they are getting and how.
