cheapest sound card with optical/coax out for DD?
Discussion in 'Computer Components' started by mince bigalow, Oct 22, 2003.
  1. mince bigalow
    mince bigalow
    hi all, I cant seem to get the optical output on my Videologic SonicVortex2 working in XP (driver issue i think) and I desperatley want to get DD working. What is the cheapest sound card that will allow me to output dolby digital to my amp via either optical or coaxial SP/DIF? Will spending more on a card actually increase the sound quality seeing as its just sending the digital signal to my amp and not decoding or anything?
  2. Steve1138
    Steve1138
    me too !!
    All I can get from my HCPC's sound card optical audio out is PCM audio (I think) at either 44 or 48 kHz
    If I select the SPDIF output in either WinDVD or Theatertek I get nothing... then I have to change back and restart the player software to get anything.
    Card is Terratec Aureon 5.1 fun with optical I + O
    does a card need to specifically state that it is DD / DTS compatible for it to be able to pass the stream through to an external procesor ?
    I would have expected to pass any type of stream through to the output
    http://www.avforums.com/forums/showthread.php?s=&threadid=97953
    Steve
  3. mince bigalow
    mince bigalow
    hi mate, i think just a pass thorugh is fine and my card didnt say DD on it and used to work fine on win98, it just doesnt have drivers for XP
