Cheapest Price for Sony HS10?
Discussion in 'Projectors, Screens & Video Processors' started by Dayv M, Mar 22, 2003.
  1. Dayv M
    Dayv M
    Mar 22, 2003
    16
    Hampshire, UK
    I am looking to buy a Sony VPL-HS10 and so far the lowest price that I have found is around £2100. Does anyone know where I may be able to buy for less than this?
    Also, I assume that buying from a highstreet specialist will cost me more, but may give some added piece of mind. Does anyone have an opinion on this?
    Finally, I read somewhere about 'dead pixels'. What is the general feeling about the likelyhood of this being seen on the Sony and how easy is it to get the store/retailer to mend or replace?
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Dont worry about a High Street specialist, go to Nexnix, you cannot beat there customer service and a good price too.
    The HS10 can be bought cheaper from Japan but with the possibility of a failure problem existing (mine is one of a couple being swopped Monday by Nexnix after two months instead of sending it for repair:) good on them). I glad I paid a little extra and bought it here.
  3. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Should add Nexnix will do a dead pixel check for £20.
  4. Dayv M
    Dayv M
    Mar 22, 2003
    16
    Hampshire, UK
    Thanks for that, I'll go look at the nexnix site and keep you posted on how I get on.
    Dave
  5. Dayv M
    Dayv M
    Mar 22, 2003
    16
    Hampshire, UK
    I ordered the HS10 from Nexnix by phone (so I could get them to do a dead pixel check) Monday morning and picked it up from their wharehouse/offce in the afternoon.
    Tried it out yesterday with my PC (via DVI) and DVD Player (S-Video) and all I can say is [insert swear word of choice] awesome!
    When using the PC the picture appears as sharp as my LCD monitor (both running at XGA resolution) but 80 inches across!
    Geometry appears perfect (unlike my widescreen TV) and I cannot see the 'chicken wire' effect unless I get really close.
    Now all I need is an AV amp, speakers, ...
