Doctor Smith
Does anyone know the cheapest place to buy a beamax m 10015. I will be using a jvc x3. Or any alternative screens. Thanks
Hi Doc
the 10051 is available in 1.2 or 1.5 gain material with black backing, it really does go well with an X3, especially the 1.5 gain for 3d use if in a non batcave room.
may I make a suggestion though, if budget allows to go with the 10607, this is the same screen but tab tensioned and i`ll make you a promise will lay and stay much flatter than the other non tabbed screen.
this is the screen we use and recommend with the JVC & Sony and regularly use them with good results.
Or if you don`t have a batcave give some serious thought to a Draper ReActII screen, this will perform much better than a matt white screen in a non light controlled room with reflective surfaces.
if you need any more info give me a shout
Allan @ Ideal AV
Can't afford a tab tensioned what with the credit crunch coming back
How much for a 10015 1.5 gain.
Loving the x3 still by the way!
Hi Allan
How much would an electric react II screen be - size 92 diagonal , And what are the dimensions of the case (length ,depth and height)?
hi Allan
thanks for that , what is the overall length of the casing ? , as it needs to fit in a certain place.
Also availability / delivery timescale?
thanks again
Hi Barney
sorry I forgot that bit, the case length is screen width 80" or 200cm + 28.5cm so making a total of 228.5cm`s
availability is 2-3 weeks from point of order
Allan![]()
can we conduct any business of the forum please
