cheapest pal progressive scan dvd player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jamiev, Jan 5, 2004.
  1. jamiev
    jamiev
    Jan 4, 2004
    923
    +36
    hi, what is the cheapest pal progressive scan dvd player? what else in a home cinema set up is required to get the benefits of pal progressive scan? ie projector , cables, etc..?
    thanks
    cambridge audio 53 player, sherwood amp (5.1/dts), gale speaker set, soon- pjtx10 projector.
  2. Bradford Blade
    Bradford Blade
    Nov 10, 2003
    2,705
    A local non-league ground...
    +724
    Hi Jamie,
    AFAIK, the cheapest DECENT pal/ntsc prog. scan is the Sony 930 (I think that's the model no. but I might be mistaken). It tends to go for around £250 if not cheaper. It also boasts SACD and Sony's QS components. I've seen it operating and for the money, it's a corker.
    As for cables, I use 3 x QED's Silver Reference SR75 0.5 mts (obviously, the shorter the better). PQ is awesome on my Panny prog. scan CRT (sorry, no idea on projector's etc.)
    All the best,
    LAGAVULIN
  3. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    There are loads cheaper than £250 but many are rubbish. There are 4 different ways of deinterlacing prog scan along with many other variables. Prog scan done badly is worse than any half decent interlaced only. The Yamaha s540 might be worth a look at around £120. Mixed reports on it, recent thread going on it in DVD Players forum as I type. £250 can certainly get you a good one HK DVD25 (or 2550 silver) is a cracker.
    cheers
    Croc
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Yam 540 £99.95 at RS and superfi branches!
  5. Ged
    Ged
    Apr 29, 2002
    925
    +17
    Out of interest..
    Sony 930 for dual prog scan and SACD,
    Pioneer 565 for SACD/DVDA and NTSC prog,
    and then much more for all of the above?
    Ged
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    HK DVD 30 for DVD-A and PAL/NTSC prog scan. but yes a bit more:)
