cheapest pal progressive player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by tonycommander, Jan 6, 2005.
  1. tonycommander
    tonycommander
    Nov 1, 2004
    2,005
    Malvern
    +142
    just to try component on my new pwd6, (and yes I can believe that there is a big change in quality the further up the ladder you go)...
    But, just wanna see what a cheapo(ish) player can do!
  2. beecee
    beecee
    Dec 8, 2003
    2,108
    Kirkcaldy, Fife
    +325
    Pioneer DV-370, only £70....
  3. Andy_t
    Andy_t
    Jun 29, 2004
    69
    Toshiba SD240 - under £60 in some places.
  4. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    Richer Sounds are selling new Limit 9900 dvd players for as low as £25. I believe the spec has pal/ntsc progressive scan plus a full 5.1 decoder with dd/dts and dvd audio. Probably a good example of a budget player. Its an old model that dates from the end of 2002 but for the money I imagine you'll be impressed. Probably a good reference model to see if more expensive models give you any extra performance.
  5. giger
    giger
    Oct 30, 2004
    241
    Solihull
    +8
    Tesco are selling the Tosh SD240 for £45 in store. I have recently bought a new TV that does progressive scan, sorry to go OT but does anyone know is this is a good for a main DVD player? There seems to be very little info that I can find on this. Currently using a Tosh SD100E which I find to be very good.
    Thanks and this is the cheapest easily available progressive scan player that I know of.
  6. Andy_t
    Andy_t
    Jun 29, 2004
    69
    What Hifi gave the sd240 five stars and said it was better than the sd330 which is two models above your sd100 so I would have thought you'd be happy with it. For £45 you can't really go wrong!
