cheapest gc pci card 2 run halo
Discussion in 'PC Gaming & Rigs' started by rooney, Oct 21, 2004.
  1. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    a friend of mine has just bought halo for his pc wich wont run .the machine he is running it of is a time xp 2000 with 512 ram with a intergrated graphics card no agp slot (damn cheopo motherboards)he needs the cheapest pci graphics card there is that will run halo on min settings ive been lookin at a
    Sapphire Radeon 9200SE 128MB DDR PCI this card is about 30 pounds(hasnt much more than that to spend as hes a student and nos even less about computers than me)
    (i havnt been widing him up about my new gc honest)
    thanks :confused:
  2. Sinzer
    Sinzer
    May 25, 2002
    5,828
    +1,119
  3. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,561
    Doncaster
    +1,251
    Doesent stutter on mine with my 9800 pro, but anyway it definetly wont run on any PCI card out there - they just dont do the sort of quality card you would need, in that format.
  4. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    i just bought a 9800 pro it doesnt stutter on my either
    so halo def wont run on a cheap pci card
  5. Sinzer
    Sinzer
    May 25, 2002
    5,828
    +1,119
    What res you running it at? I ran at 1200x1024 and it would stutter occasionally.
    Given the graphics were far worse than Far Cry I was pretty disappointed.
  6. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    mines set to 1024 by 768 with everthing on no stut even with tanks ghost etc
    its made such a big diff coming from a geforce 2
    on ati website i found this http://www.ati.com/support/products/pc/radeon9200/radeon9200issuesgames.html
    scroll down to halo and it gives you bug fixes so this card 9200 se pci must work with halo other wise surely there would be no bug fixes
    guessin it will the same as when i had my geforce 2 wich was perf playable
    (if it does work at least it saves grief of changing motherboard etc)
