Cheapest/easiest way to cut 80hz and below
Discussion in 'Video Streaming Boxes & Services' started by Gjn200, Apr 25, 2005.
  1. Gjn200
    Gjn200
    Hi, what's gonna be the cheapest/ easiest way to cut the lows from my main speakers. They are fed from the head unit, there is a sub fed from a pair of non fading rca's and a pair of rca'c (front) unused on the h/u. I dont want to go to the expense of running rca splitters from the h/u and a new 4 channel amp.
    Cheers.
    G.
  2. RB5 Paul
    RB5 Paul
    Dec 8, 2004
    204
    +10
    Just fit some capacitors in the positive speaker line on each speaker,go to a car stereo shop and ask them for one which cuts out low frequencies and they should have them,or if you want them really cheap find out which ones you need then go to and electronics store and buy them for pennies :D
  3. paulsgolding
    paulsgolding
    Jun 18, 2004
    112
    +6
    follow this link : http://www.the12volt.com/caraudio/crosscalc.asp
    you enter speaker impedence ie 4ohms, then the crossover point and it tells you which size capacitor you need. Remember you can put them in series/parallel to get different results.
    Then try Maplin.
