Cheapest DivX compatible player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by FlimsyFeet, Jun 8, 2004.
  1. FlimsyFeet
    FlimsyFeet
    Oct 18, 2003
    91
    Seen this for £50 from Amazon:
    Medion MD40814 DivX Multi-region DVD player
    Looking for something for my son's bedroom; he's only 3 and tends to get fingerprints all over his (my) Disney DVDs. I was thinking of getting one of these so I could give him some DivX on CD-Rs to play with instead of the originals.
    Any other options? I only want to spend the minimum because I don't expect it to last more than a year (bearing in mind the abuse it's likely to get!)
  2. jackashton1
    jackashton1
    Feb 23, 2004
    520
    +4
    hi there, did u end up buying this? I am looking for one too
  3. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    cheapest decent branded one is the Toshiba SD340 by the way. Do a hunt and i'm sure you'll find it for £80. Will blast the Medion in every way and it'll last longer but its another 30 squid.
  4. FlimsyFeet
    FlimsyFeet
    Oct 18, 2003
    91
    Toshiba doesn't appear to support SVCD - at least according to the owner's manual on Toshiba's site.
  5. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    yes it does. does everything- mp3, vcd, svcd, jpeg, possibly wma + everything else as well as component/ optical/coaxial digital out. toshiba players have done svcd for 3 yrs now. started on the sd220 iirc
  6. Welshman
    Welshman
    Does the SD340 play Xvid as well like the Medion does?
  7. Dustybin
    Dustybin
    Mar 3, 2003
    73
    Wrexham
    Pixmania has one at £41 all in if you use the £9 off voucher!
  8. GARYWORK
    GARYWORK
    ROZZAR - thanks for the tosh info - just looked it up on their site - it does mention divx and wma , as you said !
    Q1 )divx - does it have to be upgradable e.g. via cd for new divx versions ?
    Q2) will this essentially play everything off my pc and save lots of converting ?
    thanks
