Cheapest Amp with component switching
Discussion in 'AV Receivers & Amplifiers' started by jerkyboy, Oct 17, 2004.
  1. jerkyboy
    jerkyboy
    I am after a fairly cheap but half decent Dolby Digital Amp with at least 3 component inputs and one output.
    Its for use with my DVD player, Xbox and PS2 all of which I am using via component leads into my Sharp LCD.
    I am using a cheap crappy AV switch box which works surprisingle well, but now is the time to upgrade.
    Thanks for any help.
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I think the cheapest amp I can find with 3 componat inputs is the Denon 1705
    http://www.denon.co.uk/startpage.htm
    I have looked at sony, pioneer, marnatz and Yamaha and they all have only 2 inputs on all there amps under £400
