Cheapest 16:9 panel DLP p/j?
Discussion in 'Projectors, Screens & Video Processors' started by reefer, May 23, 2002.
  1. reefer
    reefer
    As the title says...
    Is the illusive Piano the cheapest DLP 16:9 DLP p/j? or are there any others. Want to feed DVD via a HCPC, so that rules the Piano out.
    Was considering the Panny AE100, but seriously gone off it. Now fancy spending a little more for a DLP, even if I can see rainbows I`d rather have that than all the lcd downsides instead.
    If i buy a 4:3 XGA DLP and feed via the HCPC then this should realise the best performance.
    Any comments welcome.
  2. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Hi M8
    Only go for a DLP you have demo'd.
    I demo'd the Optoma 753 and thought the contrast ratio was fab. But the rainbows seriously damaged my enjoyment of the movie.
    I saved half my cash by going LCD and although the contrast is not as good I find it more pleasurable to view :)
    Chris
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,217
    UK.
    +2,758
    Chris is right about rainbows - some people who see the rainbows suffer headaches when viewing for prolonged periods, so do try to demo if you can.
    If you don't suffer, then using an htpc and a 4:3 pj is a good way to start.
    My pj (Davis DLS8) is only 800 x 600 and gives an excellent picture. Plus do two pjs other than the Piano - the V-807 and the V-1080 se this thread:
    http://www.avforums.com/frame.html?http://www.avforums.com/forums/showthread.php?s=&threadid=36967
    The only posible problem areas (for me anyway) are the lack of zoom and them not being ceiling mountable.
    I guess the zoom isn't an issue if you manage to get the pj in the perfect position. I just bunged mine on the ceiling and zoomed to fit onto the screen.
    Gary.
  4. crispie
    crispie
    Have a look at the Sahara S3600, DLP
    1024x768, good contrast ration, excelent resalution, 4000 hrs bulb life, tiny and quiet.......
    and even better.....only £2290, including VAT. !!!!
