Cheaper to buy Pronto in the USA??
Discussion in 'Home Cinema Control & Remote Controls' started by JetJockey, Dec 3, 2004.
  1. JetJockey
    JetJockey
    Hi.
    I am looking to buy a decent single remote to replace the cluster I have at present.
    The Pronto and I Pronto look to be good models. As I am off to the states (Florida) in a month, and the exchange rate is good, would it be cheaper to buy out there??
    If so, can anybody give any advice or offer some links please??
    Thanks, Gerald. :thumbsup:
  2. mjn
    mjn
    May 24, 2001
    18,377
    Herts, England
    +5,462
    Yes, saving around 40% on the UK prices. Not sure where to buy over the counter, but mail order here www.bluedo.com This will give you some guide to the prices.
  3. rooster
    rooster
    Mar 18, 2002
    216
    Edinburgh
    I was looking at some sellers of the mx-500 on ebay from America. Is there any compatibility isuues with buying an American one?
  4. jaguar
    jaguar
    Nov 17, 2004
    186
    As fas as I know just one.
    You will not be able to operate X10 appliances. USA operate at 418 Mhz and Europe on 433 Mhz.
    You can use the RF function they will then both work on 418 Mhz.
  5. Pebble
    Pebble
    Nov 18, 2003
    311
    Grangemouth
    +4
    Hi Jaguar,
    wHAT ARE x10 APPLIANCES??? - A friend is bringing a Harmony 768 across fron the US for me - only $110 http://www.digitallyunique.com/sst-768s.html
    Might have to flog it if it dosn't work on my gear
    Ta Pebble
  6. jaguar
    jaguar
    Nov 17, 2004
    186
    Stuff like remote light dimmers or curtain closers.
  7. Pebble
    Pebble
    Nov 18, 2003
    311
    Grangemouth
    +4
    COOL - Don't have either
  8. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    Are you saying you can control X10 devices directly from a Pronto's RF without a IR to X10 converter?
    If so how?
    Barry
  9. JetJockey
    JetJockey
    Yes, how does that work. I have a remote controlled lighting dimmer, but it's a Home Store device, as opposed to Lutron etc.
    Cheers, Gerald. :)
