cheaper amp!!!!!
Discussion in 'AV Receivers & Amplifiers' started by pedropeps, Jul 2, 2002.
  1. pedropeps
    pedropeps
    hi
    i want to buy a new dvd player and a amp.
    please any ideas of a good cheaper amp :)
    please help me
    my budget is small
    thanks
    Pedro Soares
  2. bob007
    bob007
    My son just picked up a Sony STR-DE375 and a Cyberhome DVD player for just over £200, though the amp only has 6channel input for D/D the DVD player has D/D decoder onboard, is also DTS compatable.
    DVD plays DVD, CD, SVCD, CD-RW, CD-R and MP3's, it's multiregion.
    He picked up a satellite speaker package (5xsats + sub) £50, the weak link was the sub but has now changed that for a KEF PSW1000, so for just over £300 he has a system that has not broken the bank and has remarkable picture/sound quality to.
    Bob
  3. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Alos try and get to listen to the cheaper stuff by Sony, Yamaha and Denon if it's in your price range.
    can't give you exact models because I've lost touch a bit with what's around. Make sure you get somewhere that will let you have a good listen to whatever you want.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    His name is Pedro, not Alos
  5. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Sorry I'm incontinent with a keyboard !!!!!
    Or maybe dislexic cause it took me ages to figure out what you were on about !
  6. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Or just not attuned to my warped sense of humour :D
  7. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    50 Rue St Georges, Paris.
    +32
    :rolleyes: I wouldn't let it bother you, I can't add up in my head either.
  8. daren jackson
    daren jackson
    Just got the Denon 1602 (for my in-laws). A great amp at a great price. Richer sounds price matched it for £230 then as it was the last one knocked another £10 off.
  9. BoilingPoint
    BoilingPoint
    Sorry to be a pain M8, but I thought the 375 could'nt do DTS. Is'nt that why they brought out the 475? ;)
  10. bob007
    bob007
    Didn't say it did, if you re-read my post i think you will find i was referring to the DVD player....;)
    Bob
  11. BoilingPoint
    BoilingPoint
    Oops' My Bad ;)
  12. bob007
    bob007
    STRIKE ONE........ :D
  13. BoilingPoint
    BoilingPoint
    LOL :D :D
  14. Marv
    Marv
    Jun 7, 2002
    3,173
    Kekistan
    +1,412
    i got an aiwa amp for £160 which dose DTS/DD5.1 its very good.From richer sounds.
    Aiwa AV-D58
  15. Guest
    Marv,
    I just picked one of these up myself - can't seem to get it to run as Dolby Digital - just Dolby Pro-Logic...? Are you getting the same thing?
    def
  16. Marv
    Marv
    Jun 7, 2002
    3,173
    Kekistan
    +1,412
    Mine works fine with DD5.1.When playing a DD5.1 DvD Press the " Sorce Direct " buton, it should then change to DD5.1 .Also you are on Video 2 function on the amp arnt you?
    If it still dont work e-mail me.
  17. Guest
    Thanks for the advice - I am running on standard phono leads hence no digital, doh or what!?! I'll pick up an optical cable tomorrow and then run from Video 2...
    fingers crossed!!
    Cheers,
    def
  18. Marv
    Marv
    Jun 7, 2002
    3,173
    Kekistan
    +1,412
    Yep u definatly need a optical or coaxel lead.
  19. Guest
    Sorted! Got one this afternoon and it works a treat now! Thanks for your help!
    def
