Cheap Xbox Live
Discussion in 'Xbox Forums' started by ttagster, Mar 25, 2006.
  1. ttagster
    ttagster
    Feb 24, 2005
    74
    Just to let you know HMV are selling Halo 2 and Fifa 05 for the original Xbox for £19.99. Included with this is a years subscription to Xbox live and another headset (if you need one.)
    I don't think Fifa works on the 360 but Halo 2 does.
    ttagster
  2. kevlar
    kevlar
    Nov 7, 2005
    1,731
    +106
    Thanks but I can't find it, do you have a direct link please? well I can see it but its £60!
  3. gillette 73
    gillette 73
    Feb 19, 2006
    717
    up north
    +77
    i cant find it either looked on the website and even did a search but nothing.:rolleyes:
  4. gillette 73
    gillette 73
    Feb 19, 2006
    717
    up north
    +77
  5. towerofsong
    towerofsong
    May 29, 2005
    17
    3
    The HMV one is instore only I think. They where also doing it with Forza in Leeds. Is the 12months you get with it Xbox Live Gold? And will work on the 360? Just seems too good a deal.
  6. gillette 73
    gillette 73
    Feb 19, 2006
    717
    up north
    +77
    if you are on about the link i put on from play yes that does work on the 360.. it does not cancel out what you have going just tops it up and runs on after your current one finishes. I dont know about the hmv one as i could not find it. sorry:rolleyes:
  7. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,960
    2
    2
    Manchester
    +4,473
    Definitely works on the 360 if you're lucky enough to find one.
  8. gillette 73
    gillette 73
    Feb 19, 2006
    717
    up north
    +77
    play keep getting this bargain in stock , but boy they run out quick so if you want that offer you have to be quick. Then normally a few months later they have another bargain on.:smashin:
  9. towerofsong
    towerofsong
    May 29, 2005
    17
    3
    Good stuff i'm off to get the Forza one then :)
    Bargain for £20
  10. MarkyPancake
    MarkyPancake
    Jan 30, 2006
    17,626
    UK
    +3,789
    The Xbox codes become 12 month Gold subscriptions on the 360 and they stack up. You can store up to three years worth.
    The low cost Live kit isn't available in every HMV store.
    There was also Halo 2 Live kits for £14.97 in Currys, but you'll be lucky to find one now.
  11. ttagster
    ttagster
    Feb 24, 2005
    74
    It is instore only at HMV.
