Cheap widescreen tv
Discussion in 'TVs' started by Burns, Aug 31, 2003.
  1. Burns
    Burns
    HI.
    Please could someone recommend me a good 28' widescreen tv for no more than £400.
    Thanks,
    Burns:confused:
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Philip's 28PW6006 available for £299 here:-
    http://www.be-direct.co.uk/productDetails.asp?id=9897
    JVC AV28T25S available for £389 here:-
    http://www.rgbdirect.co.uk
    Panasonic TX28PS1 avialable for £374 here:-
    http://www.techtronics.com/uk/shop/862-panasonic-tx28ps1-crt-widescreen-tv.html?refid=priceguide
    Sony KV28LS36 available for £409 here:-
    http://www.digital-point.co.uk/model.asp?ID=381
    They're all pretty competent TVs, I guess it's up to what you like the look of best. Personally I'd go for the JVC.
  3. Burns
    Burns
    Thanks a lot.
    Chow:smoke:
  4. Burns
    Burns
    Sorry, but is it the JVC AV28T25EKS or AV28T25EKB? There is no JVC AV28T25S . On the website.
    Thanks,
    Burns
  5. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    They are both the same set. Retailers often leave out the EK bit. It just means it's the UK version. The S and B at the end are silver & black versions so make sure you get the right one.
  6. Burns
    Burns
    Thanks. How much better is this JVC AV28R25EKS? It has better sound than the JVC AV28T25EKS. Its only 30 quid more. What do you think?
    Burns
  7. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    It has a subwoofer and Surround Sound. It also has a better stand. Well worth the £30 extra if you have it spare.
  8. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    It has a subwoofer and virtual surround sound, I think you need to pay extra for the surround speakers.
    If the extra £30 includes the Surround speakers then go for it, my friend has the same exact set and it surprizes me just how good TV speakers can sound...
    Still only Pro Logic though :(
