Cheap Viera ?
Discussion in 'Plasma TVs Forum' started by db1234, Aug 27, 2004.
  1. db1234
    db1234
    Oct 18, 2002
    460
    Hi All,
    I'm looking to buy a Panasonic Viera plasma but am a bit confused over model numbers.
    www.krishav.co.uk lists two 37 inch panasonics - the TH37PA30 and TH37PE30. The only difference I can sopt between the two is the price - £1550 and £2100 respectivly.
    I've done a bit of research and the PA30 looks like an EU model of the Viera ( listed on German panasonic site ) and the PE30 looks like it is just available in the UK.
    Can anyone shed any light on the differences between the models ? Is it another case of rip off Britian ??
    Cheers,
    Darren
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    Would be surprised if it's 'that' much of a technical difference between the models.
    Give them a call and find out ! It's a fabulous price if all it is, is a European model. Incidentally it also appears as if it comes with 24mth warranty on the euro sites ?
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    Ok I take that back, it appears there is no reference to a Digital Tuner on board the PA30 on any of the Euro Panasonic sites. It maybe the PE30 is the only one with a Digital Freeview Tuner on board which would make sense as you don't get Freeview in Europe.
    Still, you can get an STB if that was the case ? Ring them and find out for sure anyway.
  4. Genesis
    Genesis
    Aug 11, 2004
    196
    +3
    Correct me if I am wrong, but I don't think the TH37PA30 is a Viera.
  5. db1234
    db1234
    Oct 18, 2002
    460
    Thanks for the feedback guys.
    I think Ekko Start is right - the same as the UK model without the tuner. I'll give them a call later today.
  6. ums69
    ums69
    Well, I have one and it says VIERA on the right top corner of the plasmaset.
  7. Genesis
    Genesis
    Aug 11, 2004
    196
    +3
    UMS69,
    I stand corrected! :suicide:.
    Where did you purchase your TH-37PA30.
  8. ums69
    ums69
    I live in Sweden so for me Germany is really the right place to
    order PlasmaTV.
    I order Panasonic KIT-TH-37PA30EJ-SO (stand)
    At least 300-400£ cheaper then the lowest internetshop in Sweden.(NETONNET) Including with delivery and insurance !
    Look here
  9. sabujo
    sabujo
    Ekko Star is right. My Viera has no freeview tuner in it. Couldn't use it anyway. It does have a nice analog tuner though.
