Cheap TOSLINK cable OK for Sky+?
Discussion in 'Sky Digital TV Forum' started by Stevie G, Aug 7, 2002.
  1. Stevie G
    Stevie G
    May 2, 2002
    641
    +34
    Just had Sky+ installed and I want to connect it to my Marantz SR4200 receiver. The Sky+ box has TOSLINK out for DD. Letropacks do a cable for £11. Will this be OK, or should I pay £30 for a Qunex or IXOS one? Will there be much difference between the cheaper and more expensive ones?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I am no expert but the cables I got from Lektropacks for both my SKY+ and DVD player are working great. I am not prepared to pay a huge premium price on high end cables/interconnects unless I was spending thousands on hardware and even then I would still wonder if I would be able to tell the difference:)
  3. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    50 Rue St Georges, Paris.
    +32
    £11 is at the upper end of what you should pay for a Toslink.
    My Skyplus+ is connected by a super-duper Ixos, it sounds exactly the same as the £5 Tandy predecessor.
  4. Stevie G
    Stevie G
    May 2, 2002
    641
    +34
    Thanks! I'll give the £30 ones a miss then and get the £11 one....!
  5. tk212
    tk212
    Argos do a pretty decent 2m optical cable..
    Hitachi £12.99 item number 534/1221. It even comes with a minidisc adapter, but i use this for my sky+ and its fine :)
  6. Bal
    Bal
    Mar 10, 2002
    2,181
    Berkshire
    +317
    Do a search on Ebay for Toslink - there is a guy called Andy Smith who does decent toslinks in varying lengths.
    I bought a 4 meter one off him for £8.99 incl P&P.
    Bal
