Cheap top quality 4mm banana plugs
  • Thread starter Deleted member 30535
  • Start date
D
**** Although I started this thread in Jan 2008, CPC have special promotions from time to time. so keep your eye open if they are not currently on offer *****
Top quality banana plugs on special offer at CPC. Only a couple of days to go I believe.
EDIT: 8 April 2012
[-]Original bananas are now over a £1 but the same maker has some new ones with screw connections which is really neat.[/-]
Pricing back down at an attractive 48p each + delivery if you buy 10 or more.
PRO SIGNAL|PSG03481|BANANA PLUG, 4MM, BLACK, GOLD | CPC
PRO SIGNAL|PSG03480|BANANA PLUG, 4MM, RED, GOLD | CPC
Buy 10 or more and it's more or less 50p each plus posting which may be expensive depending if you get other stuff.
I like these because you can either enter the cable on the top or the side. Side entry allows them to be stacked if messing about with bi-amping/wiring at the amp end.
shodan
Thanks Mr Incredible. You really are a hero! I've ordered 5 of each.
nero0410
Cheers :smashin:
Lot better than the plastic things I got
tris
CJROSS
I bought these after Mr.I posting the link above, brilliant VFM. Really good plugs IMHO.
PSD
Just got 20 of these, thanks for sharing the information.
DES-Lite
Getting the onkyo 605 and the jamo 102's in a few days... how many of these will i be able to use (just 5.1 for the mo)...ps i know i dont need them really... but while they are this price
D
Got mine today.
This is going to be a real silly question, but what is the best way to terminate these?
Is it just feed the wire in the back and try and poke it out the side a bit and screw down? The fact the thread goes all the way down means you can't terminate them like it is shown here:
http://www.bluejeanscable.com/store/speaker/Speaker_cable_termination.pdf
It seems to me they could work loose quite easily.
For a top entry (missionary) as opposed to a side entry (spoons) just push enough cable through the center spindle and pull enough through one side entry hole to be able to double up on itself and pushed back through the other side of the side entry, if you see what I mean. Then tighten the knurled end up. If you really want to get thorough then people have been known to solder the wire into the banana plug. But for me I'm happy with the hand tightened nut.
D
Searching for the part number won't work. Click the links I gave. They still work; I just tried.
EDIT:
Well. although the links work, you get an error on buying one. Sorry, looks like the deal is finished. For now! These have been offered on a special before, so I'll keep my eyes open!
trainspotter
EDIT:
damn, I just tried also. Never mind hopefully they will be available again.
D
You should get an email notification if I post here again. Assuming you have email notification turned on in your user profile.
I put these in my basket few weeks back and couldn't decide if I wanted them. Since putting the price up, I decided I wanted them and went back to my basket and they were still there for the old price. I managed to checkout and got them delivered couple of days ago. Excellent bargain! :smashin:
amadan
PSG01681 — PRO SIGNAL — 4MM PLUGS, GOLD, BLACK .
[*] Colour:Black
[*] Plating:GOLD
[*] Size:4mm[/LIST] Availability
Availability: In Stock
Price For: 1
Minimum Order Quantity: 1
Order Multiple: 1
Unit Price: €1.36 (€1.65)
Qty
we get screwed over here:mad:
D
The UK price is now about the same I think. (£1.12 inc VAT)
BTW, you mustn't link to images directly on another web site without their permission: it is seen as bandwidth theft. My images were captured and uploaded to Flickr.
Dubplate
these seem to be back in at 50.5p each - although i get a £7 handling charge (inc VAT) seems a bit excessive?
:EDIT: the handling charge is P&P - I thought I was going to get charged both lol I've just ordered 20 :D
Latest News
iFi Audio launches NEO Stream music streamer with DAC
  • By Ian Collen
  • Published
Musical Fidelity launches M6x 250.7 multi-channel power amplifier
  • By Ian Collen
  • Published
Is Google set to rival Dolby Vision and Atmos?
  • By Ian Collen
  • Published
'Tizen TV by Samsung' brands coming to UK?
  • By Ian Collen
  • Published
Denon announces five new 8K AV receivers
  • By Ian Collen
  • Published
