Cheap TH42PA20
Discussion in 'Plasma TVs Forum' started by sacd, May 16, 2004.
  1. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    Someone has offered me their display model for 2000.
    Is this good value?
    How many hours on the clock would make it bad value?
    It will have a full guarantee ETC
    Any thoughts?
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    the only way to know if it is worthwhile is to look for yourself.....
    ad
  3. kace
    kace
    Hi Sac,
    I'd suggest saving a couple of hundred quid more and investing in a new unit straight out the factory.
    Last thing I'd like is to inherit someone elses 'latent' problems in something that I forked so much out for. You have no idea if they ran the unit in properly i.e. kept settings low for the 1st couple of hundred hours etc
    Good luck. Feel free to ask questions.
  4. Elvis
    Elvis
    Sounds like a good deal. Check that there is no screen burn first then make sure there is no other obvious damage to the unit and insist on a full manufacturers warranty. If you see any defects or they won't play ball with the warranty then walk away.
