Cheap solution for HD-DVD
Discussion in 'Desktop & Laptop Computers Forum' started by andyr300, May 3, 2007.
  1. andyr300
    andyr300
    Apr 9, 2006
    2,134
    +104
  2. Mad Monk
    Mad Monk
    Feb 12, 2007
    1,012
    London
    +110
    I'm building a HTPC and was wondering if I could use this in my build. Is it really as simple as connecting it via the IDE as you mentioned?
    Will I need any special software to use this drive or will any HD DVD playback software do?
    Seems like an absolute bargain
  3. andyr300
    andyr300
    Apr 9, 2006
    2,134
    +104
    you will need regular HD-DVD software as with any other drive (powerdvd is the player of choice i believe)
    you will need to buy an ATAPI to IDE connector to plug it in
    other than that it will work just fine in a PC, just need the drivers which are easily found i believe.
    only problem is it needs a bit of chopping to fit in a standard 5.25" drive bay
  4. Mad Monk
    Mad Monk
    Feb 12, 2007
    1,012
    London
    +110
    Thanks for the info.
    I dont mind playing around with cutting up my case. I have a Dremel which I have never used :D
    Just gotta order some HD DVD's now..
  5. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,809
    Oxfordshire
    +170
    Just resurrecting this thread with a question about the "ATAPI to IDE" connector. I was under the impression that ATAPI was just a transport protocol. Any chance you could post a link to an example of one of these connectors please as I'm having trouble locating one? Cheers.
  6. Zarch
    Zarch
    Jan 23, 2003
    3,577
    Sheffield
    +833
  7. jakey
    jakey
    Jun 13, 2005
    855
    43
    +185
    Actually it's not just a standard ATAPI to IDE conector, the drive uses a custom pin configuration. Details are posted Here on avsforums, you will need to do some extensive and delicate modifications, just too much hassle IMHO, especially now that the Toshiba internal HD DVD drive is available.
    Good luck :rolleyes:
  8. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
  9. jakey
    jakey
    Jun 13, 2005
    855
    43
    +185
  10. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    That's where I got mine-excellent service, I would definately recommend them. :thumbsup:
  11. Burned
    Burned
    Aug 18, 2005
    313
    Macclesfield
    +5
    Hold on, thats an internal HD-DVD drive for the xbox 360?
  12. andyr300
    andyr300
    Apr 9, 2006
    2,134
    +104
    itsn still quite pricey isnt it!
  13. Bretto
    Bretto
    Jul 2, 2004
    624
    46
    Hayes, Middlesex
    +101
    Snap! Dubious....got mine on order.
    Hopefully I won't have to buy a graphics card....processor and MB graphics will do it..........:confused:
