Cheap S-video cable, are these suitable?
Discussion in 'Cables & Switches' started by Hallsy, Mar 14, 2005.
  1. Hallsy
    Hallsy
    Nov 24, 2004
    685
    Suffolk
    +14
    Basically I'm trying running all video through my amp, so will have to try S-video connection to TV as I have no component in. I want to try this to see if I can tell much difference against a (currently) average scart connection for DVD, everything else such as TV, Freeview & PS2 should look better or equal on S-video at least.
    Thing is if I don't llike it I will have wasted money if I spent a lot so, would any of these cables be OK:
    http://www.tvcables.co.uk/cgi-bin/tvcables/SV002.html
    http://www.tvcables.co.uk/cgi-bin/tvcables/SV101.html
    Or would I be better spending a little more on something like this:
    http://www.tvcables.co.uk/cgi-bin/tvcables/PGV6602.html
    If I go for s-vid as long term then I would probably purcahse one of the Mark Grant cables, as I am happy wioh the quality of my digi coax by Mark Grant.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  3. Hallsy
    Hallsy
    Nov 24, 2004
    685
    Suffolk
    +14
    Oh yeah, missed that Ixos one!!
    Ok, so if I stop being such a tightwad, and pick either the profigold or Ixos which would be better?
