Cheap Projector Screen Solution?
Discussion in 'Projectors, Screens & Video Processors' started by LG Chet, Mar 16, 2005.
  1. LG Chet
    LG Chet
    Nov 23, 2004
    125
    I currently have a Hitachi 32pd500 Plasma and Sky+
    All I want to do is sometimes watch football on a huge screen so I was thinking is there anyway to connecting a plasma or Sky+ to a projector screen directly just to get the image on a projector screen or would I need to invest into a projector?
    If so what is the cheapest projector screen that would suit the simple purpose of the above
    Thanks guys.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    LG if you don't buy the projector I think your only option is to sit closer to the plasma when watching footy. :)
    The screen is just the projection surface, albeit it is an important factor in the eventual picture quality (apparently ;) )
    The projector does all the good stuff.
    :) ...PJ
  3. LG Chet
    LG Chet
    Nov 23, 2004
    125
    Ah ok, can you recommend a cheap projector?
    thanks PJ
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    How cheap is "cheap"?
    Some people consider anything less than 5K as cheap!
    ...PJ :)
  5. LG Chet
    LG Chet
    Nov 23, 2004
    125
  6. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    MikeK makes a good point. With DVD you'll get some impressive pics, but with other sources you may see more artifacts than you bargained for...PJ
    PS the Epson is a popular machine and should fit the bill
  8. LG Chet
    LG Chet
    Nov 23, 2004
    125
    Thanks for your help chaps
