Cheap projector mount?
Discussion in 'Projectors, Screens & Video Processors' started by key130, Jun 14, 2004.
  1. key130
    key130
    Mar 21, 2004
    33
    Manama
    just got a Optima H30 projector.
    I'm planning on putting a shelf on the wall (near the ceiling) and having the H30 sitting on there.
    I get palputations when I see the 'proper' projector mount prices (£100+) for a bit of metal!
    Alternatively, I'm wondering if I can use a cheap wall speaker mount such as http://www.argos.co.uk/webapp/wcs/s...0001&langId=-1&catalogId=1751&productId=95562 ?
    They are £10 for the pair. Anyone tried being cheap like me :D ?
    Thanks,
    Al.
  2. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Well I tried the cheap option but it didn,t really work out.
  3. LongBow
    LongBow
  4. wither2000
    wither2000
    Oct 16, 2003
    151
    Bristol
    +4
    I've been a cheapskate - having decided my 100 pounds was better spent on DVDs than a 'professional mount' for the AE500.
    I bought a packet of m4 bolts and 8 right-angle mild steel brackets (about 3 inches long on each side with 2 or 3 pre-drilled holes) from the local DIY shed.
    First - Drill four holes in ceiling and insert raw-plugs. Screw on 4 brackets.
    Second - bolt the other four brackets to the mounting holes on the bottom of the projector.
    Finally bolt the fisrt set of brackets to the second set, plug in projector and set to ceiling mount (picture invert) in the menu and hey-presto projector on the ceiling for under a tenner.
    My cinema room has a low ceiling and the top of the image starts about 6 inches from the ceiling. Projector has been up there for almost 6 months now. :thumbsup:
    Cheers,
    Ian.
  5. key130
    key130
    Mar 21, 2004
    33
    Manama
    Well, finally got the projector mounted today. Ended up buying the £10 Argos speaker mounts. Work great! The projector can be tilted up/down and side to side. I've used the keystone correction to get the picture right.
    Only problem now is that the display picture is HUGE :zonked: due to the distance of the projecting wall
    I''ve attached 3 pics. I haven't tidied up the cables. Plan to use some trunking for that.
    Regards,
    Al.
  6. bobbetts
    bobbetts
    Dec 13, 2002
    164
    Norfolk
    Looks like it works well, just a couple of questions.
    1) Have you placed a piece of wood behind the projector or something, or have you removed the screws?
    2) Did you place anything at the front of the projector
    3) How sturdy is the projector in the bracket, is there any wobble?
  7. key130
    key130
    Mar 21, 2004
    33
    Manama
    The bracket comes with the sticky pads, which help cushion them against the projector. I also cut a thin strip of cardboard and placed them in between the projector and bracket. Whilst providing a more sturdy fit, they also stop the supplied bracket screws damaging the body of the projector.
    Again, sticky foam pads and a strip of cardboard.
    Very sturdy. Does not move up and down due to bolts. Can be swayed side-to-side manually however, I don't plan on touching the projector again. Even if you do accidentally move it, it's easy to sway back.
    Regards,
    Al.
  8. SCOTT_SCOTLAND
    SCOTT_SCOTLAND
    I am half way through a loft conversion and i'm at the stage now when i start thinking how to mount pj (PLVZ1).
    I myself have the same bracket but thought of a slightly different idea.
    Turn the bracket upside down, screw MDF onto bracket, then screw PJ onto MDF. I will be ceiling mounting the PJ and was thinking about asking friend who is a welder to put an extension plate onto speaker bracket thus lowering the mount from ceiling. Suppose both ways would work but i feel with the MDF it would be a mopre secure fitting.
    For the tilt adjuster you simply turn it the other way....
    Just hope it works or else :suicide:
  9. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,152
    UK.
    +2,671
    That looks like it's going to be a fantastic room when finished - nice size and small sloping roof lines. Wish mine was like that....
    If you're after a cheap ceiling mount, I've got two designs on my home page if you're interested. Both are based on cheap speaker brackets:
    http://www.g-lightfoot.pwp.blueyonder.co.uk/ht1000.html
    I'm currntly on MK 3 due to needing to flush mount it to the ceiling when I fit the anamorphic lens, so I'll put that on the site some time too.
    Gary.
  10. .scarface.
    .scarface.
    i used a punchbag bracket modified it slightly, and pj hangs from a board bolted to the bracket, it cost me about £10 - £15.
    ideal for me, as it gives me the vent clearance at the back of the pj aswell.
