cheap or diy ir receiver?
Discussion in 'Desktop & Laptop Computers Forum' started by nathsea, Jun 23, 2004.
  1. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    hi all
    anybody got any links to a cheap infra red receiver for my pc, or any links to where I could get the plans for one?
    Nathan
  2. amordue
    amordue
    Nov 13, 2002
    101
    Edinburgh
    http://www.lirc.org/receivers.html
    Then use lirc or winlirc, possible works with others too although I have only used it with lirc.
    About £3-£4 of parts (although you may end up spending more depending on whether or not you can get diodes caps and resistors in small quantities).
    Alex
  3. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    many thanks for the prompt reply..
    I sort of understand that, but would prefer if I could lay it out on hole board, with more detailed instructions!!!
    So for the second attempt where could I get a cheap IR receiver from?
    Nathan
  4. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    ve just found this page with just want I need - Many thanks to amordue for pointing me in the right direction, will have to now try and source the parts!!
    Nathan
  5. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    having just looked on the RS website I`m really confused about which bits to get as there are lots of different types of the same thing, by the looks of it. Also you have to buy lots of each item, has anybody built something like this before and has lots of bits left over or can source the bits individually?
    Many Thanks
    Nathan
  6. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    I bought one from here about £9 delivered IIRC :)
    Dave
  7. nathsea
    nathsea
    Apr 26, 2003
    920
    +24
    looks like a bargain to me, what software do you use with it , could I use Girder?
    Nathan
  8. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Sorry, missed this :oops:
    Yeah I use girder and the igor plugin for controlling my HTPC :)
    Dave
  9. Quantum
    Quantum
    Dec 14, 2003
    238
    Smethwick Nr. B'ham,UK
    will girder control theatretek with any IrDA device ?
  10. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Girder will control anything you program it to ;) IrDA is different to IR btw, don't get them confused :)
    Dave
  11. Quantum
    Quantum
    Dec 14, 2003
    238
    oh right so if i buy an IrDA device it wont work ?
