Cheap Multi Region DVD player for PC
Discussion in 'Desktop & Laptop Computers Forum' started by jerkyboy, Apr 6, 2005.
  1. jerkyboy
    jerkyboy
    I am after a cheap, but half decent DVD player for my PC. I also want to be able to make it multi region.
    Can anybody recommend a drive, and please tell me how to make it multi region.
  2. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Well you can buy a DVD recorder and flash the firmware to make it region free, or you can use software such as DVD Region +CSS Free or region killer.
    See;
    http://www.dvdidle.com/dvd-region-free.htm
    I personally like the NEC 3520 currently £37.01 from Aria.co.uk.
    You can get region free firmware for loads of models from;
    http://forum.rpc1.org/dl_all.php
    Bear in mind though that if you flash the firmware and it goes wrong you could screw up the drive. It is quite easy though :)
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    An alternative is AnyDVD, or the FREE version of DVD43.
    Flashing drives really isn't needed, the only benefit is that some firmware hacks remove the 'rip lock', a crippling mechanism built into the standard firmware that prevents the drive from reading at greater than 2x speed when it thinks that its' being read by a DVD ripper. If you don't rip DVDs to hard disk, or do so infrequently then IMHO it's dubious whether flashing the drive is worth it.
