Cheap homemade HTPC setup with LCD flatscreen
Discussion in 'Home Entertainment Computers' started by SLK_DK, Feb 3, 2009.
  1. SLK_DK
    SLK_DK
    Feb 3, 2009
    Hi guys, Im new to this forum.
    Im from Denmark, Europe.
    My old 28" CRT screen died the other day, so I bought a new 37" LCD widescreen, a Hannspree 37" JT02 series.
    I only have a old Xbox (first version) for watching movies, but the old Xbox won't playback 720p movies and I can only connect it to the LCD screen with a RGB scart cable.
    But I also have a computer that I don't use anymore (always using my laptop.)
    My computer has the specs:
    CPU: Intel E2140 (I think).. Dual Core, overclocked FSB 333 (running ~2.67Ghz)
    RAM: 2GB DDR ram
    GFX: 8800 GT 512mb
    I guess it's ok for a HTPC that will play 720p movies?
    Im right now installing WinXP Prof. with service pack 3 slipstreamed.
    On my GFX I have DVI outputs, my LCD screen has VGA input. But I have a VGA cable and a DVI->VGA converter.
    Could it be "ok" for HTPC setup?
    Is there any special settings for the Nvidia card that I should make in Windows for a better/smoother picture on my LCD screen?
    EDIT:
    I have now installed a fresh WinXP Prof with SP3, installed nvidia driver etc.
    When I play a movie (divX or .mkv) the playback on my Hanspree 37" is kind og choppy, and not 100% smooth.
    Why is that? Is that the limitation of the VGA-out/input? Or is it my LCD flatscreen that is not so good?
    Is there any special settings for Nvidia that I have to do to get smooth playback?
    Im using VLC as a player. When playing the same divX movie from Xbox1 (with RGB scart to the LCD screen) there is no choppy and its very smooth.
    Please help.
  2. anth.payne
    anth.payne
    Sep 25, 2008
    561
    28
    +54
  3. SLK_DK
    SLK_DK
    Feb 3, 2009
    But I am using VLC Player.
    I just connected my 19" LCD monitor to the computer instead of my 37" Hanspree, I felt that it was way smoother.
    I guess it is my Hanspree then? Anyone in here using same LCD tv as mine, and have it connected with VGA from a computer?
    Is it possible, and would it be better if I could go from DVI (Gfx-card) to HDMI (LCD screen) instead?
    Is there such a cable? DVI->HDMI?
  4. SLK_DK
    SLK_DK
    Feb 3, 2009
    And there is tearing! Any way to Force V-sync? I tried in the Nvidia settings, but it seems that is only for 3D games? Doesnt have any effect when I start VLC, there is still tearing of the picture.
  5. DFENS 360
    DFENS 360
    Jan 7, 2009
    366
    +64
    Have you tried changing the refresh rate in your display settings?
  6. SLK_DK
    SLK_DK
    Feb 3, 2009
    To what? It can do [email protected], [email protected] - down to 640x470.
    Both have tearing.
  7. SLK_DK
    SLK_DK
    Feb 3, 2009
    Instead of doing:
    GFX card: DVI output <->DVI/VGA Converter <-> VGA cable <-> VGA Input LCD screen
    Maybe I should just buy a DVI-D / HDMI cable instead?
    GFX card: DVI output <-> DVI-D / HDMI cable <-> HDMI Input LCD screen
    Maybe it'll be much better then? With no tearing??
