Cheap home cinema speakers
Discussion in 'Home Cinema Speakers' started by Jon B, Feb 26, 2001.
  1. Jon B
    Jon B
    Hi, I'm just starting out and am about to get a s/hand Sherwood R125 Pro-Logic Receiver to be used with my Tosh SD100 DVD player and Philips 24W6005 w/screen TV. I know this level of kit is way below most of yours, but has anyone got any recommendations of suitable cheap speakers to use? I also want to use the system for CD playing as it should be better than using my PC!
    Thanks,
    Jon
  2. Mark P
    Mark P
    if your talking 'cheap cheap' why not try the SCHNEIDER HC-1 Speaker pacage. consists of 2 fronts, 2 rears and a centre speaker. (see this months home cinema mag-p86) and for £130 must be a great starter package. these are available from your local ASDA.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    How cheap is cheap? For GBP400 I would tend to look towards Tannoy Mercury (or Mx) series. Can do for less if you opt for bookshelf speakers as fronts.
  4. McBain
    McBain
    Feb 15, 2001
    181
    Fair Oak
    What about the Mission Cinema 6 combo. Haven't heard them myself, but get good reviews. Looking at about £350 mail order...
  5. Jon B
    Jon B
    Hi, Thanks for the advice. The room it's going to be used in is only a small bedroom, so I was thinking of using bookshelf speakers at the front as I think floorstanders might dominate the room both sonically and visually. What do you think? Am I right in thinking that Pro-Logic works the rears less than the digital formats so I can get away with lesser speakers at the rear? I think the missions might be a bit much for me as they cost about four times the new cost of the amp.
    Jon
  6. Jon B
    Jon B
    Hyperfi have got some very cheap Yamaha and Pioneer centre/surround speaker packages (less than £50 cheap!) advertised in What Hifi that are presumably old, obsolete stock. I think the Yamaha surrounds are E103s (not got mag with me). Has anyone got any experience with this level of kit? I was thinking of putting my very limited student resources into the front l/r speakers as, if I'm also going to be listening to music, these should be the most important ones. Am I right about that?
    Thanks,
    Jon
  7. Greyhound
    Greyhound
    Aug 23, 2000
    64
    Have you considered the Videologic all in packages? About £250 for the DD version and £370 for the DD/DTS version. The speakers are small but powerful for their size.
  8. Jon B
    Jon B
    Hi,I did think about the Videologic stuff, but this receiver came up really cheap so I bought it. Also I thought that they might sound a bit too much like copmputer kit as that's what Videologic make mostly. Or at least that's where I came across them.
