Cheap Headphone advice
Discussion in 'Headphones, Earphones & Portable Music' started by Smeghead uk, Sep 11, 2007.
  1. Smeghead uk
    Smeghead uk
    Apr 18, 2006
    10
  2. mattski73
    mattski73
    Jun 30, 2006
    386
    28
    +28
    try the Sennheiser CX300 from amazon.
    i've brought three pairs from 'Rocco' and they've all check out to be genuine. there is ahuge flood of fake CX300's, and apparently the fakes are getting better.
    http://www.amazon.co.uk/s/ref=nb_ss...aps&field-keywords=cx300&Go.x=9&Go.y=15&Go=Go
    check this info out first.
    http://www.head-fi.org/forums/showthread.php?t=257023
    http://cgi.ebay.co.uk/Sennheiser-CX300-Noise-Canceling-Isolation-Headphone-BL_W0QQitemZ190096198542 (scroll down a little)
    if you want 'headphones' then try the HD201's which are going for a song.
    http://www.amazon.co.uk/gp/offer-li...84717?ie=UTF8&s=gateway&qid=1189538944&sr=8-1
  3. Smeghead uk
    Smeghead uk
    Apr 18, 2006
    10
    Thanks for your suggestion, is it worth the extra tenner or so for the Sennheiser than the ones i linked? Can anyone else comment on these pair as on the amazon review people have been giving them bad ones aswell as good ones. The kind i want are in-ear ones not 'headphones'.
    EDIT: I think i might go for the CX 300's after reading a few review, i've seen them on play.com for the same price and i don't they would sell fakes would they? Now just to find the 3.5mm adapter.
  4. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    In the budget range you mention the Sennheiser CX300 are the ones to go for. Several friends of mine have bought them and been well pleased especially when they see what I pay for my gear :)
