Cheap (good) HTPC - What can be done.
Discussion in 'Desktop & Laptop Computers Forum' started by Tempest, Nov 12, 2003.
  1. Tempest
    Tempest
    Jan 11, 2002
    5,880
    Horley, Surrey
    +1,321
    I am thinking about having a dedicated PC for HTPC use.
    Requirements are cheap as poss to play a DVD via a Radion Card with Digital output from a Sound card and very quiet.
    I know Uvem make great kit, but (from my limited viewing) I feel these are built up to a very high level of quality that (Truth be know) is WAY WAY above what is needed to play a DVD on.
    Seeing PC's even new ones in the high street being sold for just a few £100 these days with 1Ghz+ CPU's and DVD drives I can't see how a HTPC can't be done for very little money
    No need for a large HDD, No need for anything flash at all really.
    Just a quiet case a 1Ghz ish CPU a Low End Radeon and a OEM SB Live, DVD ROM and I'd guess you'd have it.
    What would that be.. ? £300 ish ?
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    If you really wanted to push the boat out, i reckon £200 would get you a half decent system. Find an old nforce 1 board with geforce2mx built in, athlon 1800xp+, 256mb ram, 5gb hard drive. Would be pretty upgradeable up to about 2600+, 1GB ram, some pretty big hard drives, any AGP graphics card, etc.. when you get the money. My HTPC cost just over £400, excluding the DVD burner, and that was 6 months ago! Athlon 2200, 512mb ram, 40Gb hard drive, plus all the bits in my sig. Won't be upgrading it for a long time :D
  3. Tempest
    Tempest
    Jan 11, 2002
    5,880
    Horley, Surrey
    +1,321
    Thank's for the reply.
    I guess about £300 - £400 all in would seem a realistic price for a machine JUST to play DVD's.
    I'm supprised no-one here sells (or know who sells) HTPC's that are built just to do the job at a good quality.
    No Frills machines, just good quality without going overboard.
    Although I have built many a PC before, it would be nice to get a ready made one from someone who knew what worked best together.
    Cheers for the advice.
  4. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    The killer with HTPC is software to be honest, not hardware, a copy of windows with a decent dvd software will add at least £100 to the cost when buying pre-built. My £400 machine also does a LOT more than play just DVDs, i don't know why you think you'd need to up a lot in £200 DVD machine i suggested? Unless of course you're budgeting for software too. Obviously, the basic DVD HTPC will also do most normal PC functions too.
  5. whuuf
    whuuf
    Sep 26, 2003
    153
    16
    Essex
    If you shop around you can get some good software inluded with your purchases, something like the highly rated M-Audio - Revolution 7.1 sound card comes with WinDVD 4 Dolby Digital EX version, Tony Hawk Pro Skater 3, MixMan Studio, and Vjay Lite.
  6. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,718
    71
    Land of the Living, Essex
    +34
    pay for software? now theres a concept :)
