Cheap + fairly tall projector stand
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by explicitlyrics, Nov 28, 2004.
  1. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,129
    41
    NW London
    +12
    As you can tell from the title, Im looking for a cheap projector stand that is about 1.3/1.4m tall. Have tried standsunique and optimum2000 so far. I found this projector trolley Projector Trolley but just thought i would see if anybody knew a cheaper one... given it is just a metal stand with a plate at the end...
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,129
    41
    NW London
    +12
    Nobody at all?
    I might go with it coz i need it soon... any advice ppl... plz :)
  3. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,129
    41
    NW London
    +12
    Hmm, I need it to be about 20cm taller than the stand above after doing measurements. Anybody got any ideas at all?
  4. LenScott
    LenScott
    Feb 5, 2001
    102
    Edinburgh
    +6
    Have you considered building a stand yourself? I built one with similar dimensions and I'm reasonably happy with the results, just using MDF and some table legs from B&Q. I am happy to provide more information if you want.
    Regards
    Len.
  5. msrx7mh3
    msrx7mh3
    Jul 2, 2003
    1,006
    38
    London
    +13
    I'm looking at buying a PJ and given that I live in rented accomodation, a follow up to this thread would be very useful indeed!
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,129
    41
    NW London
    +12
    I bought the trolley from chaseavdirect and its awesome. really easy to put up and very useful. Much advised if you dont want to build your own.
  7. noel-pilot
    noel-pilot
    Dec 20, 2004
    ooh ouch!! £85 for a stand!! hmmm all I want is one of the ones u see in schools and uni's must be able to find one cheaper, off to ebay I go!!
