Cheap electric screens.....
Discussion in 'Projectors, Screens & Video Processors' started by JSW, May 27, 2002.
  1. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
  2. KevinR
    KevinR
    Mar 19, 2002
    102
    16
    Durham
  3. KevinR
    KevinR
    Mar 19, 2002
    102
    16
    Durham
    Bugger! me cut 'n'pastins gone awry. Do a search for 'mail order'
  4. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    OK Thanks Kev
    Not after one right now as I have made a screen to do me for a few months.
    There where some other peeps who was looking for them though.
    That company may of gone broke but the screens are still available from other suppliers.
    It is the screen which is a good price made by Euroscreen in Italy.
  5. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Video projection needs a different shaped screen to the one in the link. We use 4:3 format (or 16:9), not 4:4 format used for OHP transparency projectors.
    You will also find that good video screens have a black border around the screen edge. This helps to frame and define the picture which enhances its separation from the wall behind.
    If budget is tight but you need a roll up screen for video use try looking at the classified adds.
    Buying the wrong screen can be an embarrassing and expensive mistake.
    Regards
  6. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    The link shows more than one screen, scroll down to this one:
    112 x 200cm - Matt White - Widescreen format
    Italian made high quality electric projection screen. Can be wall or ceiling mounted. Supplied with 3 way wall switch and wall / ceiling brackets.
    Custom sizes made to order with a range of surfaces (rear, microhole, high gain, borders etc)
    -5cm BLACK BORDERS
    -PRECISE DESIGN
    -PRATICAL AND SOLID CONSTRUCTION.
    -NO NOISE MECHANISM
    -VERSATILE TO DIFFERENT PROJECTION CONDITIONS
    Bry
