C carldrichardson Guest Nov 7, 2003 #1 if you log onto the cd-wow hong site it is around £2 per dvd cheaper than the uk site & the cd's around £1.70 cheaper no vouchers easy to use!!!!!
K Kramer Guest Nov 8, 2003 #3 Log onto the .ie (Ireland) site & pay more Most members are aware of the .hk site (they even changed their checkout system - currency - previously). Good reminder though
figrin_dan Prominent Member Joined Jan 9, 2003 Messages 2,081 Reaction score 170 Points 385 Nov 8, 2003 #4 The trick is: If it's over £12, go to .hk for 15-20% off For cheaper discs get the £3 off. These are rough figures but you get the idea
paulefox Prominent Member Joined Feb 8, 2003 Messages 1,493 Reaction score 65 Points 373 Age 56 Location Bury St Edmunds Nov 8, 2003 #5 what is the address for the hong kong site
cdave Standard Member Joined Dec 10, 2002 Messages 306 Reaction score 1 Points 101 Nov 8, 2003 #6 message edited, what I needed to know is now below. (the site) Thanks
Iain Shields Established Member Joined Oct 19, 2001 Messages 787 Reaction score 3 Points 176 Age 48 Location N.Ireland Nov 8, 2003 #7 paulefox, It's here mate:- http://www2.cd-wow.com.hk/ You have to use a credit card for it to work... Switch cards etc don't work... Regards, Iain.
B boneybon Guest Nov 9, 2003 #8 when using the HK site, do u pay in sterling and if not where do you work out how much the item costs in sterling? are the cds and PS2 games the same as you would get from uk site?
J Joe Tanner Guest Nov 9, 2003 #9 You pay in HK dollars. I use http://www.xe.com/ucc/ as a currency converter.
