Cheap DVD Writer
Discussion in 'Shopping, Deals, Discounts & Bargains' started by hollie.weimeran, Feb 1, 2003.
  1. hollie.weimeran
    hollie.weimeran
    Mirror DVD RAM/-R (which is a rebadged Panasonic LFD311) is on sale at the moment at £179-99 from PC World. That is an absolute bargain as its the retail version with software. BUT*** if you live near a Staples store they are selling them at £248. They do a 150% price match so if you check with PC World to make sure they have stock Staples will sell you this drive at £150-13. Bit long winded but if you want a DVD RAM writer to complement your Panny recorder its well worth it.:clap:
  2. Dangerous
    Dangerous
    Went in to Staples to check out their price match promise. They will not price match the item you mentioned as it is on special offer.
    Thanks anyway.
    Dave
  3. hollie.weimeran
    hollie.weimeran
    I bought mine from Staples in Sheffield - They just rang PC World to verify the price and did the deal. Either I dropped lucky or you were unlucky - or both!
  4. encaser
    encaser
    Mar 15, 2001
    2,045
    Suffolk/Essex
    +379
    ebuyer are doing LF-D311 for £140.99 all in. If it's oem (aint checked) Nero will write to it anywho.
