Cheap DVD Recorder
D
dude1971
It depends what you mean by cheap? What's your budget and what do you want it to do?
Regards
Dude
kenfowler3966
And do you really mean a dvd recorder which can only record one hour at best quality, or one with a hard drive which is much more versatile, recording at least 10 times the programs at any particular quality, and gives you the ability to create dvd's with no over-run, ads etc, at best possible quality by utilising all the media for the recording, all in one box
D
dude1971
Well that's what he asked for Ken, but I take your point ;-)
Regards
Dude
Tom3316
my dads wanting to back up his old vhs on to dvd. my dads budget is about 200 but i was thinking that it may be better to get a dvd writer for the computer and a video capture card which would make it more versitile and cost effective.
D
dude1971
I'm backing up my old vhs to DVD and it's fine on the e60, he could get the e50 and it'd be ok. They're about £250.
Tom3316
i decided to buy a DVD writer for the computer and back them up on to it. thanks for the replies
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
