Cheap DVD-Ram 9.4GB
Discussion in 'Blu-ray & DVD Players & Recorders' started by JIM HARKNESS, Dec 15, 2003.
  1. JIM HARKNESS
    JIM HARKNESS
  2. TraceyJ
    TraceyJ
    Dec 11, 2003
    83
    Thanks for the link. I'm looking for dvd-r for use on my new HS2. Is this a good place to buy them? They seem very reasonable. Does the quality vary greatly between discs?
    Tracey
  3. JIM HARKNESS
    JIM HARKNESS
    Hi There
    I have purchased from these people before without any problems
    However you could also try
    www.bigpockets.co.uk
    www.blankdiscshop.co.uk
    I have used them both and they are also good for supply of reliable cheap DVD-R discs
    Regards
    Jim
  4. TraceyJ
    TraceyJ
    Dec 11, 2003
    83
    Thank you Jim. Will check them out :)
  5. sparkybun
    sparkybun
    Jan 6, 2002
    1,237
    41
    EN8 area
    +23
  6. jda
    jda
    Got one of these from a computer fair to try (cost £7) , can't tell how good it is or not since I can't get it out of the caddie.
    Any ideas?????
  7. bobones
    bobones
    Jan 15, 2002
    453
    +7
  8. jda
    jda
    Excellent, I knew there would be an easy way. I was just about to get the pliers on it.
    Thanks....
    Jim
  9. jda
    jda
    I finally got the RAM out of the caddie and recorded on it but get
    DISC ERROR...
    When trying to load it now.
    See "JVC DR-MS1SLB problem!! " thread.
    Any one had any luck with the Datasafe media?
    Jim
  10. daveyboy
    daveyboy
    Forgive my thickness....but am new to this.
    I have enquired about the double sided dvd ram disc. Does this play on DVD Players or do u need a dvd recorder??
    I also have a multi format dvd player...will it play on this?
  11. jem
    jem
    Sep 24, 2002
    527
    +7
    It will play on Panasonic DVD players but not others.
    What do you mean by multi format DVD player?
  12. daveyboy
    daveyboy
    I meant to say multi format burner.....my apologies!!:rolleyes:
    Thanks for that
  13. bobones
    bobones
    Jan 15, 2002
    453
    +7
    It will play on official dvd multi drives as these support DVD-R, DVD-RW and DVD-RAM. So called "super multi" drives like the LG 4040 also support DVD+R and DVD+RW. Dual format drives support DVD+ and DVD-, but not DVD-RAM.
    So have you really got a "multi" drive?
  14. daveyboy
    daveyboy
    No....i have a dual format drive!!
    Told you i was new to this dvd lark!!
  15. Faust
    Faust
    Dec 21, 2002
    3,230
    UK
    +669
    Why do you want to take it out of the caddie? The ideal of the caddie is to offer greater protection of the disc so it increases its longevity. They are easy to remove, but I have never felt the need to do so.
  16. keylion
    keylion
    Oct 13, 2002
    212
    Lancashire
    +9
    Have ordered 3 double sided RAM discs from www.blankdiscshop.co.uk and they work perfectly in my E50. No difference in performance from the Panasonic ones - just a lot cheaper.
    Work fine on a Panasonic pc drive as well.
    Regards,
    KL
  17. jda
    jda
    Do any machines take RAM discs with caddies, mine certainly doesn't. I suppose the Panasonic may.
    see http://www.optodisc.com/product.html
    for details on how to remove.
  18. Yuccaman
    Yuccaman
    Mar 23, 2003
    101
    Compatible Panasonic DVD Players will only accept RAM without the caddy.... Not sure about PC DVD Drives though....
