Cheap DVD player advice required!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Commited, Feb 18, 2005.
  1. Commited
    Commited
    Thinking of buying a dirt cheap DVD player soon (to replace my Wharfedale 705S which is a bit dodgy).
    Choices:
    Panasonic DVDS27: £45
    Toshiba SD402: £50
    Aiwa HTDV90 MR: £40
    Yamaha DVDS520: £45
    Pioneer DV535: £50
    Cyberhome DVD402: £50
    Or - to throw a spanner into, I could spend an extra £50-70 to get a DVD Recorder, which seems like the obvious choice!
    Yamada DVR8000: £120
    Relisys RDVR250RU: £100
    Tangent DVR500: £120
    Any help?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    23,134
    Warwick
    +3,760
    I would narrow your options to the Panasonic, Toshiba and Pioneer models out of that lot.
    ...all of which listed are fairly c*** DVD recorders (and players for that matter). To get a decent DVD recorder you need to spend around £200.
  3. Commited
    Commited
    Hmm - any more advice?
