Cheap deinterlacer any good?
Discussion in 'Projectors, Screens & Video Processors' started by gingercat, Aug 11, 2003.
  1. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +26
    I found this cheap (£36.05) deinterlacer at Lik Sang. The spec actually sounds quite good:
    Anyone think it's worth getting for hooking up my digibox to my AE100?
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,320
    Newcastle
    +216
    Only way to tell would be to get one & compare, but there's a good chance that the de-interlacer in your AE100 would be just as good...
    Cheers,
    Liam
  3. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    No, these cheap deinterlacers aren't any good. To be honest, they are not even deinterlacing - they are line doubling. Essentially they take each interlaced frame and double it into one frame. This frame is then outputted to the VGA output.
    To the naked eye, you get a hi-res image on-screen, but it looks flickery and really bad. You are not getting a proper deinterlacer here that is turning two interlaced frames into one proper frame. I used one of these at work on a PSone (supposedly the highest quality device too - about £150) and the picture was AWFUL...
    Avoid.
  4. They
    They
    Sep 10, 2002
    171
    16
    Bristol
    The term 'line-doubling' is a mis-nomer and very much mis-understood by most who use it.
    In essence, a de-interlacer converts interlaced video to progressive video, if that is what this cheap product does then it is still valid to call it a de-interlacer regardless of the method used to achieve the progressive video output.
    Doing de-interlacing well is not necessarily expensive, a very good de-interlacing IC can be purchased in quantity by manufacturers for around $20 each and not much else is required in hardware terms to go with it. Many home cinema video processing systems are very much over priced, although or course, it is still true that you get what you pay for for the most part at the moment, but one day someone will bring out a damned fine de-interlacer scaler with DVI etc for about £199 or less. Or am I still dreaming!
  5. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +26
    From their description of the product, it isn't simply a line-doubler, as it refers to "3D motion adaptdive de-interlacing" which is found in the more expensive de-interlacers - it's this feature (and the noise-reduction) I thought may make it worth while for me.
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,499
    2
    71
    High Wycombe, Bucks, UK
    +59
    For the money you can't lose. unless it's broken.
    I have no doubt it's better than my Video Cheese Box, which is pretty poor. (but then it's relativley ancient tech).
  7. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +26
    Well, I've just ordered one, so I'll let you know how it fares when it arrives...
  8. ReTrO
    ReTrO
    Jul 12, 2000
    3,499
    2
    71
    +59
    Cool. Look forward to some piccies of it at work.
  9. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    I got one of these premium vga boxes for my PAL gamecube. The quality through composite (and you can't do 60hz) was awful so I bought an official nintendo component cable which delivers interlaced component to the adapter. The quality is improved, but still dodgy. Flicker is a real pain at time. It would be nice if there was something like this that upconverts 50hz to 100hz and 60hz to 120hz and gives you a decent quality pic.
    I wanted a cheap, but half decent way to play my cube games on my vga monitor.
    Any suggestions for better models. Or do I have to go for an iscan pro ultra.
  10. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +26
    Well, in the end I got the same model as Zoolap (before reading his mini-review).
    Basically, the quality is pretty much the same as you'll obtain by running your sources through a ProV box i.e. not all that great for LCD. The handy thing (for me) is that it means I can feed my Freeview digibox to my PJ with less interference along the way (as suffered by long composite leads).
    To sum up, if you were thinking of getting a ProV just as a means of converting from composite (or other)->VGA, then one of these boxes will do just as good a job for much less money (and no tuner), but don't expect miracles!
