Cheap Decent Banana plugs?
Discussion in 'Cables & Switches' started by Stew, Sep 13, 2004.
  1. Stew
    Stew
    Feb 1, 2003
    52
    Hi all, :hiya:
    I'm after some decent banana plugs for my 5.1 setup (so they have to be cheap ;) )
    Speaker cable is FFRC (in single wire configuration) so its quite thick, not sure what gauge it is? :confused:
    solder type is out as is crimp type as I don't have the tools for that.
    Any suggestions are most appreciated :thumbsup:
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    I got mine from here. Free recorded delivery within 2 days. Done the job fine for me.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I got mine from www.ardelectronics.com for my previous AV system. They have a screw fix for the cable so are easy to connect to the speaker cables.
    Mark.
  4. Stew
    Stew
    Feb 1, 2003
    52
    thanks for the replies, the ardelectronics link keeps timing out for me.
    any more suggestions?
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I did find their site very slow when checking them before posting the reply to your thread. They could be doing overnight backups etc. I suggest you take a look in the morning and see if you have more luck then.
    They have 3 or 4 different sets from about £1.50 to £3.00 for a set of 4 plugs.
    Mark.
  6. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
