Cheap DAC
Discussion in 'Hi-Fi Stereo Systems & Separates' started by aka, Nov 18, 2003.
  1. aka
    aka
    I want to upgrade my old CD Player and intended to connect it to a DAC. Is there any cheap DAC around 100 - 300 pounds? (with good decent sound)
    thanks before..
    rgds,a-k
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    Look out for a Arcam Black Box on E-Bay thay are supposed to be OK.
  3. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    Try the Cambridge one over at Richer sounds. Or wait on e-bay and try to get a BB50 or Roksan ROK-DA1. Either of those will out do a new Cambridge DACmagic. The early BB's sound dated, so beware!
  4. SKA.face
    SKA.face
    I have a Micromega DAC from 1998,It was £700 new,i'm selling it for £210 - 300€,I'm selling it as i bought a CAL audio lad dac instead ,i live in spain so post may be a tad more about £25.[​IMG]
