Cheap DAC for CD63 SE? Worthwhile?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by mrrinse, Nov 2, 2004.
  1. mrrinse
    mrrinse
    Just wondering if buying a cheapish s/h DAC - say a Cambridge Audio S700 Isoplatform DAC - would be a significant uprgrade to a Marantz CD63 SE. Any other recommendations, suggestions or advice appreciated.
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    You will need to spend around £200+ on a DAC to improve/alter/change the playback from your 63SE IMHO, the CA DACs whislt good additions for cheap CDPs or DVD players, is a different level to your 63Se, think of MF DAC & Meridian, Audiolab & TAG. Plenty about.
