Cheap Component Input Selector
Discussion in 'Plasma TVs' started by RHCP, Sep 25, 2005.
  1. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
  2. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    just stick a composite lead in if you want cheap
  3. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    I'll get my coat!
    Only asking,
    it could be fantastic and a bargain!
  4. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    sorry mate no offence intended,it may be very good and the truth is i dont know,
    price is of course very important as long as the device works within the tolerance of your equipment seems like a good buy
  5. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    having another look and now feeling embarressed and wanting to help.the dearer one comes with a power pack which would suggest there is some sort of signal boosting going on, wheras the cheaper one is just a switch, IE a knob with connectors on it and probably no further circuitry,if you have the money then i think it would be money well spent getting the dearer product,the cheaper one may turn out to be ok but if quality is an issue, you may find yourself wishing you made the other choice.
  6. Rapid 17
    Rapid 17
    Jan 14, 2005
    837
    28
    +74
    I seem to remember that someone on these forums bought the cheaper one recently and was very pleased with it.
  7. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    I think I should clear something up here!
    First, the Master Component Controller does come with a power pack - it requires a tiny tiny bit of power.
    Second, it's based upon the What Video & Widescreen TV Accessory of the year - So you know it will be excellent.
    Third, yes, it is a switch. Fully automatic, detecting when the Master input is active. THERE IS NO KNOB!
    The Master Component Controller is a electronic switch, using high quality parts with a bandwidth in excess of 80MHz. It's designed to be very transparent, keeping all the picture detail.
    I designed the Master SCART Controller and Master Comoonent Controller as I do with all my design, looking to ensure that the electronics are performing at their very best.
    Sorry, IJD, I think you've got totally the wrong end of the stick with our products!
    All the best,
    Dr John Sim.
  8. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    quote"Suitable for DVD players, video game consoles and other AV equipment
    • Switch device for selection
    • Allows you to connect 3 AV Component devices to your TV set
    • Switch between 3 YPbPr (component) inputs
    • No extra power supply required XXXXXXXXXXXXXX
    • Suitable for DVD, VCD, PS2, GC, N64 and XBox
    yes i totally got the wrong end, as you can see by where i have marked it says no extra power required, whereas the other comes with a power pack,
  9. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Play nice boys,
    i think symanskis read your post wrong ijd.
  10. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    symanski, i was not implieing you product was of poor quality but that maybe it did not completely do the same job,
    IE i bought a usb splitter, it did not do what i wanted it to do, i had to buy one with a power supply and it worked,
    i do come on here to learn and i am always happy to be corrected if what i say is incorrect :lesson:
  11. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    IJD - No problem, may have miss-read the post. Trying to watch the GP at the same time...
    John.
  12. the highlander
    the highlander
    Mar 29, 2005
    160
    Bonnie Banks O' Loch Lomond
    i have a JS Master Component Controller and mighty fine it is :thumbsup:
    i also have JS rgb to component converter as well .
    both work flawlessly and do what they are designed to with great ease :smashin:
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,418
    The Borders
    +2,591
    RHCP
    The difficulty here is how to judge these products.
    The JS Technology products are very low cost for what you get - and for someone with two sources the inbuilt switching 'logic' makes for an easy life :)
    As Rapid_17 says some folk have found the very low cost passive switches meet their requirements whereas other folk would fire a couple of test patterns via one of these devices and point out its limitations.
    I think you'd have to have both units in front of you and try them in your system to judge if one of them degrades the signal more than the other and if one of them is more flexible in its operation.
    Best regards
    Joe
  14. Carl Stock
    Carl Stock
    Jan 29, 2004
    743
    46
    +109
    Hi. :)
    I just thought I would add that I have two Master SCART Controllers from JS Technology, and they are brilliant! They are easily the best SCART controllers around. Quite simply, they work. Many others’ SCART controllers do not, however – I had tried so many up until I tried the Master SCART Controller. Everything works on different makes of TV, too – widescreen; sound when needed through SCART; Sky+; Freeview, DVD…
    Also, JS Technology are very helpful – quick, easy service. You can order one directly from JS Technology.
    Regards,
    Carl :)
  15. Peabo
    Peabo
    I have one of these. I use component leads worth over £50, but if I connect them directly to the plasma, or through this switch, I can't tell the difference. That said, the switch is very dodgy; you have to fiddle with it to get sound on both channels.
  16. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Send it Back, I'm sure they'll change it for you!
  17. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Very strange. The connectors on the circuit board are soldered directly, there shouldn't require any "fiddling" to get them to work. I'd double check the leads, but we're more than happy to have a look at the Master Controller for you.
    All the best,
    Dr John Sim.
  18. Peabo
    Peabo
    nothing to do with the leads, i've double checked that. I use the 2 way switch, not the 3 way though. You have to sometimes move the switch around a bit to get both audio channels.
    Oh, and it's not the JS box I'm using, it's the one the guy originally asked about.
  19. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    In that case, I can only suggest that you try one of our products instead.
    All the best,
    John.
  20. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Looks like this has answered my original question, and if i do end up buying one it will be the js box.
    Cheers all! :)
  21. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    We get there eventually!
    All the best,
    John.
  22. watusi
    watusi
    Oct 1, 2005
    490
    sheffield
    +17
    Symanski,
    The JS boxes look interesting, are there any plans to make one that has more than two inputs?
  23. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Sorry, no, but because we use such high quality switching circuits you can use one to feed a second to give an extra input again. We've had several customers doing this with the Master SCART Controller.
    All the best,
    John.
  24. Member 55145
    Member 55145
    Jan 18, 2005
    12,071
    +3,489
    i preffer quality in my products, but here i dont see any bonus other than not having to get up to switch the box, if you really want to go the cheapo route and not have to bother switching anything, buy three phono splitters that join two phono plugs into one. you just have to make sure that the other device is turned off at the time.
    simple, effective and about a quid each :D and you dont have to worry about signal loss either as its a straight pass thru :clap: ... and if you want to add another component device splash out another £3! :smashin:
    EDIT: here you go £2 each
    http://www.maplin.co.uk/Module.aspx?ModuleNo=34195&doy=10m10
  25. watusi
    watusi
    Oct 1, 2005
    490
    sheffield
    +17
    Has anyone actually tried this?
  26. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Not a good idea as you don't know what each source is doing when off. Some people have tried this with SCART splitters, horrible devices. Came to me asking why the picture quality was dropping.
    All the best,
    John.
  27. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    I feel ashamed to admit this, as I imagine all the purists will lambast me for the cheap cop out but Jago's idea works perfectly for me. I have the gold plated connectors from Maplins as per the link. I tested the quality of the picture and was fully prepared to buy a JS Component switch box if I wasn't happy with the phono splitter performance @£6. Well it worked brilliantly for me so I never pursued the JS option. I have a PS2 and Panny DMR-E500 both feeding into a single component input on a Panny TH-37PE30B plasma. Obviously you can't have both items powered on simultaneously otherwise you get interference but there is zero interference when one is switched off and the other live. I even tested the pictures produced using DVE by connecting the PS2 to the TV only then unplugging and connecting the E500 exclusively to the TV and finally connecting both via the splitters to the TV.
    Works for me! :smashin:
    S.
  28. Member 55145
    Member 55145
    Jan 18, 2005
    12,071
    +3,489
    you would say that as your a manufacturer, at the end of the day deviced should be designed NOT to interferre at all (In a perfect world they wouldnt yea) but when things with component out are turned off they are off, its a safe bet that it will work, and as SteveP said below it worked perfectly for him, its just like pluging it straight in, best £6 you could spend
  29. Mr Eddy
    Mr Eddy
    Feb 26, 2005
    220
    Has anyone tried one of these? SKU Component Switch Expensive but would give digital sound switching too.
    I tried one of these Cheap Switch and it is poor. Subject to interference and the swich is poor.
    I like the 2-1 solution! What happens when both devices are on?
  30. Member 55145
    Member 55145
    Jan 18, 2005
    12,071
    +3,489
    you get interfference, thats why i said you can only put one on at a time...... which normally shouldnt be a problem anyway, and my way means no turning nobs or pressing buttons other than on the device you want to play :D
