Cheap Center Speaker help
Discussion in 'Home Cinema Speakers' started by ruddles, Nov 9, 2003.
  1. ruddles
    ruddles
    Can anybody help me as I want to buy a cheap center speaker for my home cinema setup my old one just went bust. I have seen this one http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301622 at richersounds for £49 so basically is this ok its just for a small bedroom. As you can probably tell I don't have a clue on this sort of stuff so any help would be much appreciated thanks.
    Ruddles. :rotfl:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Decent choice for the money what speakers are you using for the fronts as that is important.
  3. ruddles
    ruddles
    Well I have a cheap Acoustic solutions 5.1/sub setup it was only £80 but I find it quite effective and just need to replace the center at the moment.
    I would consider getting a whole new speaker package if I could find something decent for a reasonable price.
    cheers.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    M71 and that centre wil get a better setup for the front assuming you are using a reciever for the speakers and it isnt an all in one type. £100 of upgrades but huge improvement???? (down to your ears really mate!) as centre is knackered a mission front 3 would make sense.
  5. zoolander
    zoolander
    I read that the m7c1 isnt all that great and have a different tonal balance to the rest of the m7 series as they are in a super comact plastic case.The m7c2 is about £100ish if u look around and is far,far superior,in fact it matches the m71's perfectly as they use the exact same drivers albeit the m7c2 has 2 instead of 1 for better dispersion.I currently use the m7c2 and all i can say is that for movies,it has no right to sound so clear and detailed for such a cheap speaker!If u have a silver TV the silver finish looks sweet when placed on top.Wont be upgrading this centre for a while.....ok,maybe the m5c to match my m53's:D
    zoolander:D
