sinistro
Established Member
I want a small cheap, silent, low power usage pc to connect to my led projector (DVI/HDMI) 1080i/720p/480p.
As the resolution aint so high I dont expect I need a very powerfull machine to be able to play still nicely.
I thought to use the amd a10-5700 first but or the same amount I could build something with a i3 also. So what about this:
i3 3220
ASUS P8B75-M LX
2 x 4gb 1600 ram kingston cl9
graphic msi gt640 2gb
500 watt psu corsair cx v2
m-atx tower tacens noa
deepcool fan
500gb hd seagate
so round the 500 euro
or what a shop did gave me a price for:
amd a10-5800
asus f2a55-m fm2
4gb kingston ddr3 1600
b-move 600 watts
deepcool fan
tacens noa m-atx
500gb seagate hd sata3 7200
which comes round the 400 euro
The shops one is cheaper but does not have a dedicated graphic card so if I would add one there it will be more or less the same price.
Which would be better and will it work or should I build it up around a i5 minimum?
i3 3220
ASUS P8B75-M LX
deepcool fan
500gb hd seagate
amd a10-5800
asus f2a55-m fm2
b-move 600 watts
deepcool fan
tacens noa m-atx
