Cheap AV receiver stop gap
Discussion in 'AV Receivers & Amplifiers' started by GreenEagle, Jan 28, 2004.
  1. GreenEagle
    GreenEagle
    Jan 16, 2003
    Maidenhead
    Can anyone suggest a cheap AV receiver with pre-out for about £300 to use with a Rotel RB1090 as a stop gap until I have funds to buy a five channel amp and processor later in the year.
    I will consider second hand gear.
    I thank you
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,195
    2
    +3,667
    Yamaha DSPAX640 is (I think) £300 at Richers and has a full set of pre-outs. It also has pretty good effects steering so will be an adequate processor for a meaty power amp
    Which power amp is it going to be incidentally?
  3. GreenEagle
    GreenEagle
    Jan 16, 2003
    Maidenhead
    I am using the Rotel RB1090 with a Rotel RC971 preamp (which to be honest is not the best). But I now need a heapo amp for multichannel until I can get a 5 channel amp at then of the year.
