Cheap As Chips Recommendation
Discussion in 'Home Cinema Buying & Building' started by Mr Eddy, May 4, 2005.
  1. Mr Eddy
    Mr Eddy
    Feb 26, 2005
    220
    First off this is a 'friend' who has asked this so don't give me a hard time.
    Assuming they spend a maximum of £120 what is the best surround all in one system out there. That really is the financial limit and they are no audiophile. So what can be got for that price or lower that is bearable?
    PS They only want to spend £99 but I didn't dare post that sum.
  2. jakehake
    jakehake
    Apr 29, 2005
    20
    3
    maybe a RicherSounds trade offer, usually a couple of deals within that price range
  3. blackhammer
    blackhammer
    Dec 18, 2002
    325
    +7
  4. Clabs
    Clabs
    Nov 5, 2003
    135
    +7
    Take a look at the offerings from Acoustic Solutions. They are available from Richer Sounds and Argos. Don't be put off by the price - they really are amazing for the money. I bought one after listening to one my mate bought. Last year, I had some money burning a hole and bought a much more expensive JVC unit. It wasn't a patch on the Acoustic Solutions unit so it went straight back to Richer Sounds.
    If your mate buys from either of the above suppliers, he has 14 days to take it back if he hates the sound of it.
    Cheers, Clabs
