Cheap Android unlocked or easily unlocked phone required with long battery life
Maniac618
Hi all,
Can anyone recommend a long battery life android smart phone that is under £50 and unlocked or easily unlockable?
Thanks for any help.
finbaar
No such thing exists. The best battery life on a Android phone is the Motorola Razr Maxx and this costs about £300ish sim free. Other than that there may be a cheaper option if you get another phone that has a compatible Mugen high cappacity battery, but the battery on it's own will cost £50.
JethroUK
I charge my battery over night, every night so battery life has never been a consideration ever since they started making mobile phones batteries that lasted a whooooooole day (my first Motorola flip phone lasted 2 hours max on std battery, or you could buy optional long life battery which was the size of a small toaster :D)
