"Cheap" 5.1 speaker package.
Discussion in 'Home Cinema Speakers' started by PhilJam, Jan 22, 2005.
  1. PhilJam
    PhilJam
    Jan 18, 2005
    85
    Maesteg
    +7
    I have just bought a Sherwood 6095 receiver off this forum. I was thinking of purchasing the Yamaha NSP100 speaker packakge from Richer Sounds for £80. I want to get back into Home Cinema via the "seperates" approach but for very little outlay. For the last 3-4 years I have had to put up with a Sony DAVS300, which sounded OK with DVD's but not with CD's.
    Do you think that my proposed system will sound better than the Sony?
    Thanks for your time.
    PhilJam
    Can I just add that I have only joined this forum this week, but I find it absolutely brilliant.
  2. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    Im afraid you wont know until you try them all out.
