Cheap 5.1 for the bedroom!
Discussion in 'Home Cinema Speakers' started by LDJ, Dec 31, 2003.
  1. LDJ
    LDJ
    Jun 18, 2003
    605
    +27
    Basically, having got the living room sorted, I now want a cheap 5.1 setup for the bedroom. I currently have a 32” w/s TV with basic pro-logic and I’m tired of the very ordinary sound that results. What I want to do is upgrade this to 5.1 so that my Xbox and movies play in lovely DD5.1, and ideally I’d like DPL2 for sky, but I want to do it as cheaply and aesthetically economically as possible.
    I’ve been looking at the all-in-one HC systems but they (obviously) come with DVD players – something I really don’t need. I’ve already got more DVD players than I know what to do with, so another is most unwelcome! :)
    Can anyone recommend a half-decent 5.1 setup that wont break the bank – I don’t mind if its through a all-in-one speaker ‘kit’ or separates…just something that will do the trick so to speak.
    thanks
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Sony's DAVS550 is pretty descent for a smaller room. If you want something meatier (but equally as gorgeous) try the company's DAVS880 or DAVS888 systems instead, which are both VERY respectable performers.
  3. FlimsyFeet
    FlimsyFeet
    Oct 18, 2003
    91
    I've just got myself the Creative Inspire 5.1 Digital 5700 system. It would be good for a smaller room & console gaming, doesn't have DPLII but has something else that sounds like it's Creative's attempt at designing a circuit to do the same thing. The system got good reviews in What Hi Fi and Home Entertainment, but I bought it because the price is down from the RRP of £250 - you can now pick one up at PC world for £150 or QVC for £130! (and after I said how crap QVC was...)
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,091
    notts.
    +64
    Hi LDJ
    Try and pick up the sony htk-25 there are still a few about for under 200 quid(no dvd player) i put one of these in my daughters bedroom which is 18'x9' and it sounds excellent ,It used to retail at around 370 quid .
    Cheers Gonzo.
  5. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,091
    notts.
    +64
    Empire direct are doing the new model htk-250 for 219 quid.
    Cheers Gonzo.:)
  6. LDJ
    LDJ
    Jun 18, 2003
    605
    +27
    thanks gonzo: the htk-250 looks just the job!
